12/5/2022 6:48 AM | |
Joined: 1/21/2013 Last visit: 4/25/2025 Posts: 3775 Rating:
Hi, first, you should determine how many PowerTags the project uses. This will be found inside the TIA Portal when selecting the WinCC RT Advanced in the project tree and select "Properties…" in context menu. The required information will be displayed at "General ▸ Information". 128 PowerTags is the smallest possible license. If this license is already used and not sufficient, you can upgrade to the next possible amount 512. This would be possible using 6AV2104-2BD00-0BJ0. Kind regards |
12/5/2022 9:32 AM | |
Joined: 7/5/2013 Last visit: 4/25/2025 Posts: 3149 Rating:
Hello, after readin entry of K_Ohjus, you may try with latest version of Automation License Manager, see Handling programs for authorizing or licensing SIMATIC products. ( ALM, TIA Administrator, Authors). Regards, Frink |
Pi is exactly three! |
