1/11/2011 2:16 PM | |
Posts: 2964 Rating: (484)
Hello.... Could you check the base offset any value is entred it should be zero. Check it out.. Regards, Ekalavya |
1/11/2011 2:53 PM | |
Also if there is some place to get some tutorials that info would be greatly appreciated. Hi... Details of basic fundamentals of milling attached.... hope this will helps you....check it out Regards, Ekalavya Attachmentmilling1.pdf (126 Downloads) |
