4/24/2016 12:42 PM | |
Posts: 487 Rating: (36) |
Hi If you think you realy need more than 2048 bytes of memory then you should start using datablocks You can also use local memory ( size to be set in hardware configuration) which is 'local' to the block itself. Eric |
4/24/2016 2:53 PM | |
Joined: 1/4/2013 Last visit: 9/7/2024 Posts: 1123 Rating: (101) |
Why dont you use dbs and look at memory estimation that tia makes ? So you will not get mad about calculating the amount of memoryby yourself but you will have a true result |
Searching for Siemens used/new equipments ? |
