11/5/2009 3:27 AM | |
Joined: 9/27/2006 Last visit: 1/26/2023 Posts: 11943 Rating:
Hello PCBuctot; TIA is a concept, "Totally Integrated Automation", upon which control hardware and software from Siemens is built. Or, put another way, every up to date hardware and software element from Siemensintegrates the principles and standards of TIA to facilitate communication between plant processes.So you can use any software (Step 7, WinCC, WinCC Flexible, Simatic PDM...) to take advantage of the TIA principles. The following link will take uyou to the Siemens TIA portal, with a multimedia presentation of the principle of TIA, and links to much more information on the subject. https://www.automation.siemens.com/sites-static/TIA/en/index.html?HTTPS=REDIR Hope this helps, Daniel Chartier |
