3/6/2007 9:13 AM | |
Posts: 3149 Rating:
Hi as far as I know the interface in your panels is not active, but this is necessary for using this usb-adapter. You can use the adapter with a S7-cpu or e.g. a repeater. In the following cataluge page 2/25 you can find a table showing possible cables/adapters https://www.automation.siemens.com/salesmaterial-as/catalog/en/st80_n_e.pdf?HTTPS=REDIR http://support.automation.siemens.com/WW/view/en/19109408 nemo |
3/8/2007 2:15 AM | |
Posts: 83 Rating:
Thank you all for the the replies. Really helpful. hgq |
