2/7/2012 1:48 PM | |
Posts: 1 Rating:
hi all kindly , i need a list of the siemens touch panels which have a FDA ( Food and Drugs Administration). certificate. |
2/7/2012 2:29 PM | |
Joined: 4/22/2010 Last visit: 1/15/2025 Posts: 5697 Rating:
Hello, I don't know such list You can do a little research yourself here: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&siteid=cseus&aktprim=0&extranet=standard&viewreg=WW&objid=10805558&treeLang=en Or contact your local Siemens rep. [url=https://www.automation.siemens.com/partner/index.asp?HTTPS=REDIR®id=WW&lang=en&comptcid=o] Contacts Worldwide [/url] Regards, Marcjan |
Problem solved? |
2/7/2012 2:49 PM | |
Joined: 4/24/2006 Last visit: 2/10/2025 Posts: 8843 Rating:
Hello, You should (can)use the options WinCC flexible/Audit, WinCC flexible/Logon and WinCC flexible/ChangeControl. Perhaps these links might help: What are the functional differences between the different SIMATIC panels? Remote Control of Operator Panel in Application requiring Validation in the Pharmaceutical Environment Printing of WinCC flexible/ Audit Documentation of Production Processes with WinCC flexible Best regards, Wizard |
2/8/2012 7:50 AM | |
Posts: 378 Rating:
Hello, just to make the list of entries complete What support does Siemens AG offer to make use of panels comply with FDA regulations? Best regards Bilao |
