9/18/2012 6:45 AM | |
Joined: 3/2/2009 Last visit: 8/6/2024 Posts: 94 Rating: (8)
Dear luigi.mazzoni, I recommend to contact Siemens Customer Support. Regs, grg |
9/20/2012 8:35 AM | |
Joined: 9/2/2012 Last visit: 8/15/2024 Posts: 711 Rating: (30) |
Dear mazzoni, i have faced the same problem with ipc 577c. Its because of driver problem. Search in C/D drive for the driver backups,in that you can find UPDD driver. Install the driver first. If driver is not installed, callibration option in control panel will be like cemented. After installing the driver, you can find driver under updd console popup in control panel or (start->programs->UPDD->settings) . please find the attached file. Attachmentipc touch callibration.pdf (2372 Downloads) |
7/24/2018 5:20 PM | |
Posts: 1 Rating: (0) |
What did you do for solve this problem Best Regards |
11/8/2019 4:59 PM | |
Posts: 16 Rating: (0) |
I got same problem |
