2/23/2017 8:30 AM | |
Joined: 4/10/2006 Last visit: 2/17/2025 Posts: 951 Rating:
Hello i done one hardware with CPU 315F-2 PN/DP, CP 343-1 Lean and operator panel TP1200 Comfort. (see attachment). My problem is this: when i connect into CP with VPN, you can only see the software into CPU BUT ISN'T POSSIBLE COMMUNICATE WITH MP1200 COMFORT! How i can do for solve this problem? is possible? thank you Roby Attachmentethernet.pdf (196 Downloads) |
2/23/2017 8:42 AM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello Roby Do you use PLC Proxy??? (https://support.industry.siemens.com/cs/de/en/view/73502293) Could you please send us further information about your Network configuration? I´m not sure but in your case It could be that the PLC cannot do a etnernet routiing without a foll integration of the HMI in PLC Project. Bye Murof |
2/23/2017 8:53 AM | |
Joined: 7/9/2015 Last visit: 3/21/2025 Posts: 4204 Rating:
Hi, I think you must activate S7-Routing function: Please check this: How do you enable cross-project S7 Routing in the TIA Portal and in STEP 7 V5.x?
Regards, Towome |
