12/12/2018 7:57 AM | |
Posts: 1 Rating: (0) |
Hi, i have TP170A Simatic Panel and its part number is 6AV6 545-0BA15-2AX0. Several times i tried to connect it with my PC using USB / PPI Multi master cable. (6ES7 901-3DB30-0XA0) I use for it RS232 IF 1A port and all DIP switches keep in off position.(DP/MPI) Enable serial transfer mode in Transfer setting. Unfortunately its not success. Please can you help me for solve this issue . Thank you ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/12/2018 12:32:52 PMNew subject after splitting |
