5/17/2013 4:06 PM | |
Joined: 4/24/2006 Last visit: 4/28/2025 Posts: 8971 Rating:
Hello alessandro1911, You should perform an OS update with the option "Reset to factory settings" See this link: how do you do an operating system update (OS update) on operator panels? The image version depends on the used software, see this link: What connections are there between the version designations in WinCC flexible? Best regards, Wizard |
5/22/2013 3:01 PM | |
Posts: 3037 Rating:
Hello, You start a support request for your problem with your TP177 B. Most probably it is no software problem but a hardware problem. Tweety |
