11/7/2008 9:22 AM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hi, what panel did you use?. I did not heard about a panel call "TP200". Did you know this faq -> http://support.automation.siemens.com/WW/view/en/19701610 The best are you try to use a "Reset to factory setting". Notes the info in the docment under chapter 2.1.2 When this does not help, then i think the panel have a defect. -> Call your local siemens partner. Furthermore, you can look to this info. -> http://support.automation.siemens.com/WW/view/en/22639376 regards, |
