11/14/2010 4:48 PM | |
Joined: 3/21/2006 Last visit: 2/6/2025 Posts: 10239 Rating:
Hello, Did you met the same problem with this panel before? Are you sure that download the project again will helps? I suggest you to try with calibrating the touch screen. Look at http://support.automation.siemens.com/WW/view/en/23335365 (Calibrating the touch screen). Perhaps this is the problem there... Best regards, Hristo Mihalev |
