2/24/2016 3:32 PM | |
Joined: 2/5/2016 Last visit: 4/6/2022 Posts: 8 Rating:
hello all i have an tp700comfort pannel and its my first experience to work with hmi when i want to download program from pc to hmi i see this error i'm tried reset to factory and update for several time but they didnt solve my problem if its posible please help me thanks ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 2/24/2016 3:57:11 PMNew subject after splitting |
2/24/2016 5:17 PM | |
Joined: 8/31/2013 Last visit: 3/20/2025 Posts: 607 Rating:
Hello I not sure but maybe because there is no any from your HMI transfer ports active try to go and set the IP to transfer your program by using Ether net TCP/IP. If it is the same comes Try to upgrade your Firmware by using Prosave program https://support.industry.siemens.com/cs/attachments/19701610/19701610_ProSave_e.pdf |
Last edited by: Min_Moderator at: 2/25/2016 11:02:27 AMEdit link to permanent one. Warm Regards |
2/28/2016 10:59 PM | |
You have to contact with Siemens Support and tell them about this problem |
Warm Regards |
