4/7/2017 10:40 AM | |
Joined: 8/3/2009 Last visit: 3/14/2025 Posts: 14990 Rating:
Hello Fmadrid I´m sorry but the Webserver is the only way to get access to the SD Card. FTP works theoretically but only manually from the Panel (its an old FAQ but still right) https://support.industry.siemens.com/cs/ww/en/view/15250466 But you could transfer the needed Files from SD Card with a Script to a network share with the following faq: https://support.industry.siemens.com/cs/ww/en/view/92346478 Bye Murof |
