3/21/2018 9:21 AM | |
Posts: 12 Rating:
Dear Experts, I just connected BROTHER QL-720NW(Label Printer) with TP700 COMFORT.The print command working fine but the main issue is printed letter was scattered and Barcode also .So we can't able to detect that barcode through barcode scanner.Kindly give anyone right solution for this .Am trying this to solve for past 1 month .I also attached the printed letter for your further clarification. Best Regards, Agasthiyabalan. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 3/21/2018 9:41:14 AMNew subject after splitting |
3/21/2018 10:10 AM | |
Posts: 12 Rating:
Tks for your reply. when connected this printer with PC it work fine but not with TP700.I used to take printout by report option in TIA14. |
3/21/2018 10:44 AM | |
Posts: 12 Rating:
Sir, In printer properties ,I just selected brother QL650TD V1.4 but am using brother720nw in that i can't select draft mode. |
8/25/2018 9:22 AM | |
Posts: 12 Rating:
Hi, Print command is nothing but when i press print button on hmi screen it work successfully but still nw i didn't solve the barcode detection.😣 |
