4/9/2024 9:47 PM | |
Posts: 1 Rating:
Hi guys, I have faced the problem that HMI TP700, comfort fwv v17.00.00.06.. it couldn't connect with our wincc . How can I solve it ? it is just run on online but I can download a program . ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/10/2024 08:23:38New subject after splitting Last edited by: Jen_Moderator at: 04/10/2024 08:24:25Headline optimized. |
4/12/2024 12:45 PM | |
Joined: 8/3/2009 Last visit: 4/23/2025 Posts: 15338 Rating:
Hello mantime what do you mean exactly with connect? If you can transfer a projectfrom TIA Portal then everything is OK... A second thing could be to work with SmartServer on the Panel. So you will be able to connect to the Panel with SmartClient. Could you please give us some more information in order to help you? bye Murof |
