12/26/2022 3:23 PM | |
Joined: 12/23/2022 Last visit: 3/6/2024 Posts: 3 Rating:
Hi, thanks for your anwser. Yes, this is the article number: 6AV2143-6JB00-0AA0 |
12/27/2022 1:06 PM | |
Joined: 4/26/2012 Last visit: 7/5/2024 Posts: 1547 Rating:
Hello Chicco12, I was interested in the subject and opened a support request at Siemens. LINK Their answer is here: "In this case you can configure the normal KTP which you can find in TIA Portal. You must not use any functions on the buttons in the project. But you can transfer the project normally to your OEM panel." good luck |
Last edited by: rdoliveira at: 12/27/2022 13:12:14"Always make a backup before and check the best time before testing." |
1/16/2023 1:11 PM | |
Joined: 8/3/2009 Last visit: 7/8/2024 Posts: 13244 Rating:
Hello Chicco12 there is also an official manual in which you can read this information: https://support.industry.siemens.com/cs/ww/en/view/109780221/135017648907 Bye Murof |
