5/18/2015 11:02 AM | |
Posts: 53 Rating: (1) |
I'm having the same problem with TP900, any solutions? Using Tia Portal V13 SP1, tying to download via ethernet. ---------------------------------------------------------------------------------------------------- |
Last edited by: Matilda at: 18.05.2015 11:05:53Last edited by: Min_Moderator at: 5/19/2015 9:53:59 AMNew subject after splitting |
5/19/2015 10:30 AM | |
Joined: 8/3/2009 Last visit: 1/17/2025 Posts: 14593 Rating: (1818) |
Hello everybody I repeat my post from the last thread in english: Try to generate a new HMI Project and try to transfer this one. If this do not work also i would try a Reset to Factory Settings. Here ist a Manual to do it: https://support.industry.siemens.com/cs/ww/en/view/19701610 Perhaps there is a file or program on the Panel damaged or the normal functions of the panel do not work anymore. A Reset to Factory Settings gets your Panel to a clean an working state and its done in 10 -15 minutes. Wish you good luck Bye Murof |
