9/29/2014 11:23 AM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, Why use a transducer when the card can read PT 100 ? See chapter 6.7 of SIMATIC S7-300 S7-300 Module data Regards, Marcjan |
Problem solved? |
9/29/2014 2:51 PM | |||||||||||||||
Joined: 8/27/2010 Last visit: 6/3/2022 Posts: 417 Rating:
Hello! Hereit is: PT100 input - 0..10V output. Order code:8432180000 Input
Output
I used Weidmuller hundreds of times. Working good. |
9/29/2014 4:12 PM | |
Not sure about Siemens. Probably yes, but for in-head transmitter installations for temperature sensors. Checkprocess instrumentationconference. I used Weidmuller, Pepperl+Fuchs and Phoenix Contact for such applications. However, I usually used 4..20 mA instead of 0..10 V. Not all vendors have such transmitters. As for the price, usually there is no big difference between such big vendors. Basically prices are same. BR, olloy |
Last edited by: olloy at: 9/29/2014 4:14 PMI assume you understood the difference between in-head or DIN-rail transmitter installation. Unfortunately, my English isnt good enough to write more accurate) |
9/30/2014 7:12 AM | |
Posts: 102 Rating:
Thanx alot :) |
