10/20/2015 7:22 PM | |
Posts: 16 Rating: (0) |
Hi, i too have a similar problem. Is it possible to directly transfer a decimal value of 20000 from memory location to an analog output and measure the ma output. i am using cpu314ifm.it has only one analog PQW128. i have wired it to give current output. i tried monitoring with the variable table and forcing decimal values to the memory location MW4 but the monitored analog output PQW128 doesnt show the value in the memory location. I have attached a snapshot of my program and a snapshot of my variable table. ------------------------------------------------------------------------------------------ Attachmenta.rar (134 Downloads) |
Last edited by: Min_Moderator at: 10/21/2015 12:59:59 PMNew subject after splitting |
10/21/2015 8:04 AM | |
Joined: 3/21/2006 Last visit: 9/10/2024 Posts: 10228 Rating: (1181) |
Hello, Monitoring of analog output: Tips and tricks for loading and testing S7 programs or UMENCHO Hello,
If you want to monitor PQW just extend the size of process image area of CPU to cover that PQW and in variable table just write QW number. Best regards, Hristo MIhalev |
