4/12/2018 4:19 PM | |
Joined: 8/3/2009 Last visit: 4/23/2025 Posts: 15338 Rating:
Hello Marko23 you cannot use a Log on the Flash Memory itself so you mean from SD Card to USB i suppose?? -> in this case you can use the following Way to create a CSV File Copy from the logs: https://support.industry.siemens.com/cs/ww/en/view/63042926 Bye Murof |
