10/10/2011 1:47 PM | |
Joined: 3/21/2006 Last visit: 2/6/2025 Posts: 10239 Rating:
Hello, Concerning TP170B: all the options for backup/restore procedure using a CF card is mentioned at http://support.automation.siemens.com/WW/view/en/19082123 From other point of view as I see, you have both WinCC Flex and Protool software. If there is enable 'back transfer/upload option" you can try with both software to upload the project...and then using a migration options easily to "jump" to TP177... Check it How do you back transfer the projects of an operator panel and what should you watch out for? Best regards, Hristo Mihalev |
