1/27/2021 1:04 PM | |
Joined: 2/6/2015 Last visit: 2/3/2023 Posts: 80 Rating:
Hi IHolziner, There can be several causes for this behavior. You must check that you meet the following conditions: How many single segments can be connected to the SQL server in PCS 7 without impairing performance? https://support.industry.siemens.com/cs/ww/en/view/34473263 Other option is regenerated the DCF file: https://support.industry.siemens.com/cs/ww/en/view/109763043 Best Regards, CGA81 |
1/29/2021 2:55 AM | |
Joined: 8/24/2011 Last visit: 11/3/2022 Posts: 68 Rating:
Hi, Please, if you found the solution, send some news here! good luck |
4/30/2021 7:05 AM | |
Joined: 10/5/2020 Last visit: 1/20/2023 Posts: 82 Rating:
Hello, im using Unified PC |
4/30/2021 10:48 AM | |
Joined: 6/19/2017 Last visit: 1/27/2023 Posts: 6401 Rating:
Hi lHolzinger, no reply to a Support Request isn't a normal behavior Please send us the ID of the request. We would try to get in contact and get some information regarding the actual status of the request. Best regards, |
