7/30/2024 2:55 PM | |
Joined: 7/10/2024 Last visit: 9/6/2024 Posts: 42 Rating: (5) |
Hello RaffePersson!! In the properties shown in the screenshot, in the list where None is selected, if you scroll down, the different ways to dynamize a field appear. You can find more information in the following link: https://support.industry.siemens.com/cs/us/en/view/109813308/160120150923 If you want to enter these values from an I/O field to apply them in the viewer property, you must select the dynamization by variable and associate the variable used in the I/O field. I hope this information has been useful |
If you found this post helpul, I'd greatly appreciate your feedback. Your thoughts make a difference. Thanks for the support. |
8/2/2024 9:04 AM | |
Joined: 8/3/2009 Last visit: 9/17/2024 Posts: 13713 Rating: (1727)
Hello RaffePersson The best is to have a look in the object model of Unified Scripting. Here you find every property of the screen items described and how to use in script. Also the datatype is listed. For example the BeginTime Property of the Time Axis: https://support.industry.siemens.com/cs/ww/en/view/109896132/158390840459 Bye Murof |
