5/4/2012 3:25 PM | |
Joined: 9/28/2005 Last visit: 11/5/2024 Posts: 2957 Rating: (242)
I don't know if it will work, but you can create a historical log then add needed tags, but never start logging to it. Instead you can write values for a tags by a script to that log's .csv file like is described here How can you write data to a file or read data from a file by means of a script on a Comfort Panel with SIMATIC WinCC (TIA Portal)? This is some kind of workaround and has no idea if it will work. Generally speaking trends can show data from a data logs. Nothing more. Try to find some other way. |
Best regards, |
