4/8/2022 10:50 AM | |
Joined: 2/15/2022 Last visit: 12/25/2024 Posts: 4 Rating:
And there is an ather example with win cc explorer v7.5 |
4/22/2022 8:31 AM | |
Hello aymen_fraj in WinCC Prof you could use a VB SCript to "load" the F(x) graph with an Array. here you can define in the Script what you want to see. A little example you can find here: https://support.industry.siemens.com/cs/ww/en/view/109792622/45950651019 -> Example 2 -> Its a WinCC V7 manual but the funcitons in WinCC Prof are equa/similar perhaps it helps you Bye Murof |
10/12/2024 8:28 PM | |
Joined: 2/2/2016 Last visit: 4/15/2025 Posts: 13 Rating:
i am in the same problem if you can help me plz |
