4/29/2020 11:33 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello In WinCC Comfort/Advanced its not possible to dynamise the Trend view in Runtime. So you can only try to use a few (up to 8 ) Trend views in one Screens and use the animation visibility. Or you try to use a dummy archive and copy the inputs as you need like in this FAQ (But its not very easy to understand and to customize as you would need): https://support.industry.siemens.com/cs/de/en/view/109477071 Bye Murof |
