11/20/2018 10:52 AM | |
Joined: 5/14/2018 Last visit: 2/21/2022 Posts: 5 Rating:
Hello Yu-wen Tang. I had a problem when i tried connect PLC S7-1500 ( CPU 1512C-1PN V2.5 ) with MQTT broker (Azure) . The error code 80C6 and statusId = 2 when I enable LMqtt_Plublisher , i can't fix it , please help me. i attacked my problem's ducument and my project. Thanks for your help! ------------------------------------------------------------------------------------------ Attachmenterrorazure.docx (133 Downloads) |
Last edited by: Jen_Moderator at: 11/20/2018 2:52:55 PMNew subject after splitting |
11/22/2018 9:22 AM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello Yuki I think you know this FAQ: https://support.industry.siemens.com/cs/ww/en/view/109748872 But perhaps its a kind of Certificate problem reegarding the Azure Cloud... I know no other Example but perhaps you will find here also Information in this FAQ, I know its a WinCC FAQ and the Cloud is also another one (AWS) but perhaps... https://support.industry.siemens.com/cs/de/en/view/109760955 If It doesnßt help the forget the Post Bye Murof |
