2/16/2011 4:59 PM | |
Joined: 8/31/2005 Last visit: 8/20/2024 Posts: 2198 Rating: (328)
The S7 is designed to control other components, not to be controlled. You can go the half way: For STOP you can callSFC46 "STP". As far as I know the switch on the CPU or STEP7 software is the only way to activate RUN. (If you use a WinAC you can use ODK to toggle the operating mode) |
