1/4/2007 8:46 PM | |
Posts: 3149 Rating:
Hi, is the position of your switch linked with a (e.g. internal) tag? Then you could easily trigger your action, if the tag-value changes. nemo |
1/4/2007 8:55 PM | |
Posts: 1275 Rating:
How many triggers would you have? Wouldn't it work if, as Nemo mentioned, you used "upon change" triggers for all of your tags? |
1/6/2007 11:43 AM | |
Posts: 102 Rating:
Hi Xenonn Take a look at this thread: Do you have symbols for your switches in graphic pages? If yes, you can trigger your script using property change of the symbol. |
