10/28/2014 2:06 PM | |
Joined: 8/9/2014 Last visit: 2/7/2023 Posts: 17 Rating:
So I managed to create a small VBA script by modifying an example I found and it works by writing the readings from 2 encoders straight into a csv file. Unfortunately it is too slow and once it has missed the trigger point it falls over. There must be an easy solution to this but I can't find it with my limited knowledge of Siemens. AttachmentVBA Script.zip (131 Downloads) |
10/28/2014 6:42 PM | |
Posts: 33 Rating:
If you need the .csv file, trace is able to do it. First you need to save the record and then you can export it as .csv Usab |
