2/22/2022 7:47 PM | |
Joined: 6/2/2016 Last visit: 6/21/2022 Posts: 6 Rating:
Thanks Now I'm having trouble changing the boot order. I tried to send the fw_env.config to /etc folder but the error occurs as per photo. I can only put it in the JPX folder I also tried the command sudo mel-setup but there is a problem "failure in name resolution". After putting password it initializes but in the firewell of error. photos attached. I believe I have no ROOT access and my user has no superuser ------------------------------------------------------------------------------------------ Attachmentfw_env.config.zip (75 Downloads) |
Last edited by: Jen_Moderator at: 02/23/2022 10:22:21New subject after splitting |
3/11/2022 8:07 AM | |
Joined: 4/28/2015 Last visit: 8/18/2022 Posts: 2911 Rating:
Hi, su does somehow not work on IndOS, don't know why. You can use sudo -i instead, this should work. Best regards! |
