3/22/2023 1:55 PM | |
Joined: 8/8/2020 Last visit: 3/19/2025 Posts: 2 Rating:
Hello, Thank you very much for your sample. I still have an issue when I try to load the recipe tags to HMI tags automaticaly when ParameterID change. Status is OK (4) but the HMI tags doesn't change, when I press button it works, when I load the page it works but still doesn't works when the function is called by a task. see the project attached ------------------------------------------------------------------------------------------ AttachmentProject32_20230322_1453.zip (502 Downloads) |
Last edited by: Jen_Moderator at: 03/30/2023 10:38:08New subject after splitting |
3/30/2023 11:09 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
New question published by PSE_Automation is split to a separate thread with the subject how is it possible to Debug Javascript Code on the Panel, is there an option?. Best regards |
