5/3/2017 6:57 PM | |
Joined: 4/28/2015 Last visit: 3/26/2025 Posts: 10837 Rating:
Hello, you have already good answers from guys, but I want also give you my recommendations. Look to this topic, take infos as only some standard help, hope it can be helpful to you. RS485 ASCIII will be simply work with array of bytes, you can then also work with received data with next prefered action from byte sequence. Now I maybe doubt that you need use these comm instructions, probably you need use another depended to your CP/CM card on your system. What is your card, expect some 138-4DF01???? card with ASCII or 3964 protocol option. In this case you want simply test communication with f.ex. Hercules SW, you need select ASCII protocol. Sry only another recommendation to ASCII protocol, look for ASCII table somewhere in net. If you receive some data (f.ex. from Hercules SW), you'll have them as sequence of f.ex. hex values coresponding to chars in ASCII table. Look and check that, this can be your goal also, understand values and char representation due ASCII protocol. |
Last edited by: Duris_I at: 5/3/2017 7:00:51 PMLast edited by: Duris_I at: 5/3/2017 7:06:45 PMLast edited by: Duris_I at: 5/3/2017 8:09:37 PMWith best regards... |
