1/12/2007 10:34 AM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating:
One quick solution would be to use WinCC SP4 instead [:P] Salma |
1/12/2007 12:31 PM | |
1. Have you tried uninstalling and installing from the hard drive ? 2. If so then you could try reinstalling MDAC, procedure detailed in part of this FAQ 3. Also what operating system are you running ? 4.Finally are you logged on as the localadministrator and NOT logged onto a domain ? Salma |
Last edited by: Salma at: 1/12/2007 12:32 PMPlease answer all the above points. Cheers. |
1/12/2007 2:41 PM | |
Posts: 48 Rating:
I will tray to do this and I tell you what happen. |
1/15/2007 8:17 AM | |
Posts: 48 Rating:
I connect local in the network and I am trying to install the SQL server but nothing.And finally I change the hard disk. |
