11/16/2011 5:12 PM | |
Posts: 5822 Rating:
Dear HiteshDhorajiya, maybe I can give you an idea about your solution. First of all your question about the TS Adapter II interconnection between two PLC's. Check this PDF to see more. As I see your list of Hardware I found also the AB PLC. You surely know that the AB PLC will not work with the TS Adapter anyway. So what could be an alternative, have you ever spend a moment on thinking of TCP/IP? Check this Application out: WAN Access Methods and there especially the manual: Connection via Dial in/out analog Routers (English) Best regards J_Bell AttachmentTeleServiceV613e_chapter_9.pdf (82 Downloads) |
4/2/2014 2:26 PM | |
Joined: 9/1/2005 Last visit: 3/10/2025 Posts: 4113 Rating:
follow up question published by Marco_Gis split to a seperate thread with the subjectTS Adapter II connecting Teleservice 6.1 +SP2 to TS ADAPTER. Best regards CS Moderator |
