2/13/2018 5:20 PM | |
Joined: 9/27/2006 Last visit: 2/1/2023 Posts: 11948 Rating:
Hello sunny; This linnk opens up the TUV annex 1 to Certification of the Simatic Safety Systems, which lists the certified CPUs, instructions and safety blocks recognized by TUV: https://support.industry.siemens.com/cs/ww/en/view/57141289 This link is mentionned in the Simatic Safety- Configuring and programming manual: https://support.industry.siemens.com/cs/ww/en/view/54110126 Compliance of the system library elements used in the safety program with Annex 1 of the Report for the TÜV certificate
The STEP 7 Safety optional package contains LAD/FBD instructions for programming of your safety program as well as F-system blocks that have been created and tested by SIEMENS and certified by TÜV for creating an executable safety program. In the process, the F-system blocks used are automatically defined by the F-system based on the set safety system version (see section"Settings" area). To allow you to check whether the used versioned LAD/FBD instructions and F-system blocks correspond to Annex 1 of the Report for the TÜV certificate and to the versions you intend to use, these are listed in the safety summary. ProcedureTo check, download the current Annex 1 of the report for the TÜV certificate "SIMATIC Safety" from theInternet. Hope this helps, Daniel Chartier |
