2/20/2014 9:10 PM | |
Joined: 4/14/2013 Last visit: 3/12/2023 Posts: 27 Rating:
Hello Building a UDF blocks and once noticed, the inputs and outputs can be connected directly. Error message: "Incompatible connectors" Although, I had done this before ..when you want I-Q connect directl, then you can not connect and when re-raise, then you can. The question is: is a direct connection between the I_Q is normal, or should be avoided ? AttachmentUDF-W-M1.lma.zip (161 Downloads) |
3/14/2014 5:00 PM | |
Hi Thanks for the info Helmut! Erik. |
