5/18/2014 1:43 PM | |
Joined: 1/28/2009 Last visit: 3/8/2025 Posts: 6860 Rating:
Hello, I think you are missing some configuration procedure of configuration of mentioned module in PC station via SIMATIC Net.My recommendation would be reading the following manual and return here for more tips with snapshots:
SIMATIC NET Industrial Communication Commissioning PC Stations - Manual and Quick Start Configuration Manual |
Last edited by: hdhosseini at: 5/18/2014 7:34 PMLast edited by: hdhosseini at: 5/18/2014 7:34 PM |
8/3/2015 1:52 PM | |
Posts: 2 Rating:
I got the same problem. DB block name appears in the OPC scout but variables does not. Anyone found a solution to the problem? |
6/9/2017 3:32 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by Max1978 is split to a separate thread with the subject Error message when I try to connect with UA server. Best regards |
