10/16/2018 2:19 PM | |
Posts: 1 Rating:
HELLO, I Have TIA portal v10 in my pc,i m unable to find USS protocol library,how can i find it,can any body help? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/16/2018 3:29:02 PMNew subject after splitting |
10/16/2018 2:52 PM | |
Joined: 9/27/2006 Last visit: 3/21/2025 Posts: 12344 Rating:
Hello channar; The following Application example has code for control of a Siemens drive through USS, with TIA Portal Basic v10.5, You should find all you need in the different links in the example. SINAMICS S: Positioning of a S110 using S7-1200 (TIA-Portal) with USS®-Protocol (CE-X9) https://support.industry.siemens.com/cs/ww/en/view/40616058 Hope this helps, Daniel Chartier |
