8/30/2013 1:04 PM | |
Posts: 3037 Rating:
Hello, Do you use the SP2 with Update 5 for V11? http://support.automation.siemens.com/WW/view/en/56897511 http://support.automation.siemens.com/WW/view/en/58112582 Tweety |
9/2/2013 11:32 AM | |
Posts: 3037 Rating:
Hello, Can you describe more which problem do you have with KTP 400 Basic? If you test your project with the simulation, then you use Windows 7 or WinXP. If you test your project on the KTP 400 Basic, then you use the operating system Linux. Have a look in these links for S7 1200 and timer. http://support.automation.siemens.com/WW/view/en/58836417 http://support.automation.siemens.com/WW/view/en/54647747 Tweety |
9/2/2013 8:24 PM | |
Posts: 24 Rating:
It seems like its the touch panel caliberation problem..but i am not able to restore to factory settings ..i tried thru TIA portal.Please help!! |
9/3/2013 9:03 AM | |
Joined: 4/24/2006 Last visit: 5/25/2022 Posts: 8435 Rating:
Hello Jebil, Perhaps this link might help: how do you do an operating system update (OS update) on operator panels? Best regards, Wizard |
