9/19/2012 7:01 AM | |
Posts: 108 Rating:
Hi, I was attempting to use breakpoints in an SCL FB in Step 7 V11 SP2, but was not able to set the call environment as described in the following section of the online help: Setting the call environment for breakpoints. I was able to create breakpoints without any problem, but the "..." button after the breakpoints was greyed out and nothing happened when I clicked on it. Does anyone know why this might be? Thanks Jason |
9/19/2012 12:32 PM | |
Joined: 9/23/2005 Last visit: 1/28/2023 Posts: 4176 Rating:
Hi Witch PLC are you programing? |
Denilson Pegaia |
9/19/2012 9:55 PM | |
Posts: 108 Rating:
Hi Pegaia, The PLC is an ET200S IM151-8 PN/DP CPU. |
