6/14/2010 10:55 AM | |
Joined: 3/3/2008 Last visit: 10/5/2023 Posts: 333 Rating:
hi deep the values what are seeing at the end of each machine data are called as checksum values. the values keep changing depending on the value you enter in the machine data. the other thing which you have mentioned is the user data created for some local or global use in the cycles or for other application regards ram Attachmentchecksum.pdf (244 Downloads) |
6/14/2010 11:55 AM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating:
Hi RAM, Thank you very much. I will check up. With best regards, DEEP. |
