3/3/2025 9:59 AM | |
Joined: 3/28/2024 Last visit: 4/22/2025 Posts: 7 Rating:
Hi, I'm trying to use the ChangeScreenByNumber function and I get an error in return. Can you please give an example with this specific function and what do I use as second argument (Screenwindowpath) Doesn't seem to work in my case Thanks Zeev ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 03/03/2025 11:15:15New subject after splitting |
3/5/2025 12:21 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello zeev145 Check in the TIA Manual there is an example how to change a screen by number: https://docs.tia.siemens.cloud/r/en-us/v20/runtime-scripting-rt-unified/examples-rt-unified/triggering-a-screen-change-with-a-tag-rt-unified and here is also the description with a little example: If you need help understanding the screenpaths then you can also check this FAQ for a basic help: https://support.industry.siemens.com/cs/de/en/view/109758536 Bye Murof |
