7/1/2024 8:50 AM | |
Joined: 4/5/2016 Last visit: 8/2/2024 Posts: 11 Rating: (0) |
Hi Murof, Do you know any way to do it via a Unified Comfort Panel? ------------------------------------------------------------------------------------------ |
Last edited by: Wit_Moderator at: 07/10/2024 06:56:39New subject after splitting |
7/5/2024 7:43 AM | |
Joined: 8/3/2009 Last visit: 9/18/2024 Posts: 13728 Rating: (1728)
Hello gas1993 On a Unified Comfort Panel you can use Printer drivers that are preinstalled. The Problem is what do you want to print out? You can use the installed Libre office for a printout but you cannot work with a simple report as in (non Unified)Comfort Panels for example. So it is still challenging just to print out anything simple from a UCP Bye Murof |
