4/16/2022 10:04 PM | |
Posts: 38 Rating:
Hi, I spot, that the performance increased by using V17 Upd2 Image. Gruß / BR |
9/25/2023 7:01 PM | |
Joined: 1/21/2013 Last visit: 4/27/2025 Posts: 3775 Rating:
Hi MathijsVanbeselaere,
User HedebyL has not been active on the forums for a few weeks, so a reply from him may take a little longer. In general, you will need to verify that you can send your device in for a bootloader upgrade. And in general, most performance issues are not bootloader related and need to be analyzed separately. If you explain your observations in more detail, the community may be able to provide some guidance on how to improve performance. In most cases, upgrading the device version will result in better performance - unfortunately, it will also result in other bugs. But to be honest, in most cases an analysis of your project will be needed to find possible changes that will give you better performance. To have this done, you should contact Siemens technical support. Please provide more details about the device, device version, engineering version, and bootloader version. For your information, the Unified Comfort Panels currently leave the factory with bootloader version V9.0. Kind regards |
