5/29/2024 11:58 AM | |
Joined: 6/22/2017 Last visit: 1/14/2025 Posts: 420 Rating: (57) |
Do you have a siemens sales person, that you know and can help you out? In general: You will need an Engineering (ES) Licence. Unified Comfort is not sufficient. You will need WinCC Unified PC (10k) ES. (Apart from the Step7 etc... Then for your IPC you got the right package for V18. V19 is available too though. See: https://support.industry.siemens.com/cs/ww/en/view/99860269 You need to order it in the same order as the ipc. Audit (if basis is enough) and Report are available for V19 aswell, you might get the newer Versions here. You probably won't need a database. SQLite is working just fine in >90% of usecases. Hope this helps. |
