10/17/2023 7:35 AM | |
Joined: 5/6/2022 Last visit: 12/5/2023 Posts: 334 Rating:
Hi PedroDias009, There could be a few things causing this issue. I would need more information to get a fundamental understanding of your issue. How is the log configured in TIA? Are you logging on a Unified Comfort Panel or Unified PC Runtime? If you are logging to a panel is the date and time set one the HMI? It looks like there are something that it is not good configured! Best Regards |
