8/3/2006 4:04 PM | |
Posts: 3149 Rating:
Hi, please check this FAQ: http://support.automation.siemens.com/WW/view/en/11997978 For longer Engineering-time a RC-license is mandatory. Transfering licenses isn´t a problem....but you should normally use the Automation License Manager "START > SIMATIC > LicenseManagement > AutomationLicenseManager". AutorsW is just for older PCS7/WinCC/STEP7 versions.... nemo |
8/3/2006 4:37 PM | |
Posts: 3149 Rating:
perhaps you can transfer your license to an USB-stick? |
8/3/2006 5:03 PM | |
Posts: 3149 Rating:
for WinCC you should check the compatibility any way http://support.automation.siemens.com/WW/view/en/21927773 for the transferproblem you should open a service request at simatic customer support/authorisation hotline (contact > Support Request) https://support.automation.siemens.com/WW/llisapi.dll?aktprim=99&lang=en&referer=%2fWW%2f&func=cslib.cssr&nodeid0=10805082&siteid=csius&extranet=standard nemo |
