1/28/2015 6:21 PM | |
Posts: 25 Rating: (0) |
I've send you a private message with the link. |
1/28/2015 7:19 PM | |
Thank you. But I'm pretty sure it comes from Scout as all projects with a Drive since I installed Scout for TIA does not go into SP1...
1/28/2015 7:59 PM | |
Joined: 5/12/2006 Last visit: 9/24/2024 Posts: 22371 Rating: (3012)
Hello, the conversion log say teh following: <Text>Server error: Error while deboning object with Id 13307914-669645, and MetaId 6! bei Siemens.Automation.ObjectFrame.FileStorage.Client.DataStoreExceptionHandler.ServerExceptionWrapper(Exception ex) bei Siemens.Automation.ObjectFrame.FileStorage.Client.DataStoreExceptionHandler.ServerExceptionWrapper(Object sender, ServerExceptionEventArgs args) bei Siemens.Automation.ObjectFrame.FileStorage.Base.Client.BasicServerAccess.InternalRaiseServerException(Object sender, ServerExceptionEventArgs e) bei Siemens.Automation.ObjectFrame.FileStorage.Base.Command.CommonRequestBase.HandleError(EventHandler`1 exceptionAction, StorageResponse response) bei Siemens.Automation.ObjectFrame.FileStorage.Base.Command.CommonRequestBase.ExecuteForClient(Func`2 action, EventHandler`1 exceptionAction, CommandBuilder commandbuilder) bei Siemens.Automation.ObjectFrame.FileStorage.Base.Client.BasicServerAccess.InternalExecuteCommand(StorageRequest request) bei Siemens.Automation.ObjectFrame.FileStorage.Client.DataStore.BaseExecute(IStorageRequest request) bei Siemens.Automation.ObjectFrame.Private.StorageExceptionHandlerProxy.Execute(Func`2 action, IStorageRequest request) bei Siemens.Automation.ObjectFrame.Private.StoreExceptionHandler.ExecuteWithErrorHandler(Func`2 action, IStorageRequest request) bei Siemens.Automation.ObjectFrame.Private.StorageExceptionHandlerBase.Siemens.Automation.ObjectFrame.Data.IStorageExceptionHandler.ExecuteWithErrorHandler(Func`2 action, IStorageRequest request) bei Siemens.Automation.ObjectFrame.FileStorage.Client.DataStore.ExecuteCommand(StorageRequest request) bei Siemens.Automation.ObjectFrame.FileStorage.Base.Client.DataStoreBase.CommitAndContinueSession() bei Siemens.Automation.ObjectFrame.FileStorage.Client.DataStore.Siemens.Automation.ObjectFrame.Data.IStore.CommitAndContinueSession() bei Siemens.Automation.ObjectFrame.Private.ProjectHandlingHelper.CommitAndContinueSession() bei Siemens.Automation.ObjectFrame.Private.CorePersistence.InternalPersistent() bei Siemens.Automation.ObjectFrame.Private.CorePersistence.FlushAndPersistObjects() bei Siemens.Automation.ObjectFrame.Private.CorePersistence.Siemens.Automation.ObjectFrame.Private.ICorePersistenceInternal.FlushAndPersistObjects() bei Siemens.Automation.ObjectFrame.Private.ProjectHandlingHelper.Save() bei Siemens.Automation.ObjectFrame.Conversion.ConversionHandler.Siemens.Automation.ObjectFrame.Conversion.IConversionHandler.End() bei Siemens.Automation.ObjectFrame.Conversion.StartInternalHandler.Run()</Text> </Details> <Details ServiceId="80" MessageId="30" Timestamp="28.01.2015 19:20:49" Debug="false"> <Text>Error while deboning object with Id 13307914-669645, and MetaId 6! bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.Formater.DeBoner.DeBone(Byte[] buffer, Byte[]& result) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.DataPersistence.WriteCoreObjects(ISessionInfo dataSource, IList`1 positions) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.DataPersistence.FlushCoreObjects(ISessionInfo sessionInfo, IList`1 data, Boolean modified) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.DataPersistence.FlushObjects(ISessionInfo sessionInfo, IIndexTable`1 indexTable) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.DataPersistence.FlushUserSession(Int32 sessionId) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.DataPersistence.CommitAndContinueSession(Int32 sessionId) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.StorageData.CommitAndContinueSession(Int32 connectionId, Int32 clientId, Int32 sessionId, Int32 processId) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.StorageData.SyncStorageData.CommitAndContinueSession(Int32 connection, Int32 client, Int32 session, Int32 process) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.StorageDispatch.CommitAndContinueSession(Int32 connectionId, Int32 clientId, Int32 storageId, Int32 sessionId, Int32 processId) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Kernel.ServerAction.Siemens.Automation.ObjectFrame.Storage.Base.IStorageCommandVisitor<Siemens.Automation.ObjectFrame.FileStorage.Base.Command.StorageResponse,Siemens.Automation.ObjectFrame.FileStorage.Base.Command.StorageRequest>.OnCommitAndContinueSession(StorageRequest arg0) bei Siemens.Automation.ObjectFrame.Storage.Base.StorageCommandDispatcher.Dispatch[TResult,TArg0](StorageCommand command, IStorageCommandVisitor`2 visitor, TArg0 arg0) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Kernel.StorageProxy.Execute(Byte[] requestBuff)</Text> </Details> <Details ServiceId="80" MessageId="30" Timestamp="28.01.2015 19:20:49" Debug="false"> <Text>Object: '13307909-668674' doesn't exist in any session! bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.RefactoryClient.IsTransient(StoreObjectId objectId) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.Formater.DeBoner.DeboneRelations(Byte[] buffer, ObjectWriter& objectWriter) bei Siemens.Automation.ObjectFrame.FileStorage.Server.Engine.Formater.DeBoner.DeBone(Byte[] buffer, Byte[]& result)</Text> I think you should open aSupport Requestfor this case. regards Christoph
